Caroline's 2014 WRX Haru - Track/Daily Build | 2016 Track Season - Page 14 - Socal Subaru Forum For SoCal Subaru Enthusiasts: SoCalSubies.com
Home Forums Mark Forums Read
Go Back   Socal Subies > Locals Lounge > Members' Journals > Caroline's 2014 WRX Haru - Track/Daily Build | 2016 Track Season
Old 08-02-2016, 08:11 PM   #131
msawsmr
Member
msawsmr's Avatar
Fav Mod: Me <3
SoCalSubies Addict since: Jan 2015
msawsmr is learning the ropes
Default Engine Rebuild Parts List
Here's all of the fun stuff that went into the rebuild:
  • JE Pistons 99.75 mm bore
  • Manley H-Beam rods
  • ACL race bearings
  • STI crankshaft
  • ARP head studs
  • 08+ STI oil pump
  • GSC stainless valves (intake and exhaust)
  • Killer B pan, pickup, and baffle plate
  • ACT streetlite flywheel
  • ACT HDSS clutch
  • NGK 1 step colder plugs
I stuck with the factory turbo, water pump, thermostat, and a few other things.
Slow in. Fast out.
Haru WRX built by Corner Speed Tuning
msawsmr is offline   Reply With Quote
Old 08-04-2016, 10:56 AM   #132
twisty roads
Member
Car: 2011 WRB 5-door
Fav Mod: speed
SoCalSubies Addict since: Apr 2014
twisty roads is learning the ropes
How do you like the streetlite flywheel? Heard the lighter flywheel help with acceleration but are also effecting momentum at higher speeds (standard laws of inertia). Also heard the chatter upon deceleration can be excessive at times
twisty roads is offline   Reply With Quote
Old 08-05-2016, 09:17 PM   #133
msawsmr
Member
msawsmr's Avatar
Fav Mod: Me <3
It's hard to say at this point. The WRX has seen nothing but daily driving miles since the rebuild. I haven't had a chance to let the car stretch its legs so to speak and learn all of the changes.
There's a tiny spot in the clutch throw that causes an insane amount of chatter. Fortunately, this is limited to crawling out of parking lots and I just have to be aware of the clutch pedal position. Most of the time, I rarely hit that chatter-inducing spot.
Slow in. Fast out.
Old 05-18-2017, 09:48 AM   #134
twisty roads
Member
Fav Mod: speed
Hows the car doing Caroline? How do you like your engine rebuild? Did you break 1:50 yet?
