Installs, service, maintanance, repairs, custom work! In So Cal. - Socal Subaru Forum For SoCal Subaru Enthusiasts: SoCalSubies.com
Go Back   Socal Subies > SCS Vendor Storefronts > Infamous Performance > Installs, service, maintanance, repairs, custom work! In So Cal.
Old 02-28-2011, 04:51 PM   #1
infamousperformance.net
Authorized Vendor
infamousperformance.net's Avatar
Car: SpecB, LGT, LGT Wagon
Fav Mod: Custom
SoCalSubies Addict since: Feb 2011
infamousperformance.net is learning the ropes
Default Installs, service, maintanance, repairs, custom work! In So Cal.
Shop located in Escondido. Full fabrication services available. Specializing in Subarus. No job too big or small.
Address is:
1948 Don Lee Place, Suite 8
Escondido, CA 92029
Check us out of Facebook:
https://www.facebook.com/pages/Infam...6553829?ref=hl
Check us out on Yelp:
http://www.yelp.com/biz/infamous-per...ning-escondido
Phone: 760-781-1126
email: sales@infamousperformance.net
Please call for appointments.
For custom work we charge $100 per hour plus materials. For standard things we will quote a price.
Some basics we get lots of request for;
Exhaust Install Pricing (Labor)
Headers $175
Headers Back (Headers, Uppipe, Downpipe, Axleback) $450
Headers & Uppipe (Headers, Uppipe & Downpipe Only) $425
Uppipe (Uppipe, Downpipe) $350
Uppipe Back (Uppipe, Downpipe, Midpipe & Axleback) $450
Downpipe Back (Downpipe, Midpipe & Axleback) $250
Downpipe (Downpipe) $200
Catback/Axleback $75
Hardened Exhaust Hangers $75
*Prices based on stock vehicles in good working condition and standard replacement parts (no major rust, broken bolts, etc) Non-Standard installs will be billed at our regular hourly rate.
Turbo Install Pricing (Labor)
Turbo/Injectors/Fuel Pump (W/No Air Pump and Side Feed Injectors) $800
Turbo/Injectors/Fuel Pump (W/Air Pump and Top Feed Injectors) $900
Turbo (Bolt in) $400
Injectors (W/No Air Pump and Side Feed Injectors) $300
Injectors (W/Air Pump and Top Feed Injectors) $400
Fuel Pump $100-125
Mounts & Bushings Install Pricing (Labor Only)
Motor Mounts $200
Transmission Mount $100
Anti-Lift Kit $225
Front Lower Control Arm Rear Bushings (Legacy '05+, Impreza '08+) $225
Front Lower Control Arm Inner & Rear Bushings (Legacy '05+, Impreza '08+) $225
Front Roll Center Kit (Legacy '05+, Impreza '08+) $175
Front LCA Bushings & Roll Center Kit (Legacy '05+, Impreza '08+) $350
Steering Rack Bushings $200
Rear Subframe Bushings $150
Rear Differential Locking Bolts $100
Rear Differential Mount Bushings $200
Short Shifter (5MT) $100
Short Shifter (6MT) $175
Short Shifter w/Bushings (5MT) $150
Short Shifter w/Bushings (6MT) $205
*Prices based on stock vehicles in good working condition (no major rust, broken bolts, etc)
Electronics Install Pricing
Electronic Boost Gauge $200
EGT Gauge $225
A/F Gauge $200
Oil Pressure/Temp Gauge (In Block, only avail on certain models) $200
Oil Pressure/Temp Gauge (Filter Style) $175
Electronic Boost Controller Grimmspeed Style $75
Hella Horns $200
Hella Horns(Bumper Removal Required) $250
Services Included in our 30K Mile Service
Replacement of:
Coolant (Subaru Long Life) (Coolant Conditioner added on NA Cars)
Brake Fluid (Full Flush with ATE Type 200 or Standard Fluid)
Transmission Fluid (Subaru HP or Subaru ATF)
Front and Rear Diffy Fluid (Subaru HP)
Oil Change (Motul 8100 X-clean, Conventional Subaru Filter)
Fuel Filter (if applicable)
Air Filter
Rotate Tires
NGK Spark Plugs (Non-Turbo Cars)
ACC Belts (Except H6 and 08+ WRX)
Clutch Fluid
Checks on: Brakes, Parking brake, Clutch, Suspension, Fuel lines, Exhaust
Pricing:
Turbo
30k Using Conventional Engine Oil & Subaru Oil Filter $485
30k Using Motul 8100 X-clean Engine Oil & Subaru Oil Filter $530
*On 09+ Impreza/Legacy (and cars with Subaru Super Long Life Coolant) $50 discount due to the coolant change interval being 100k miles.
Non-Turbo H6 add $70 (serpentine belt, oil)
30k Using Conventional Engine Oil & Subaru Oil Filter $440
30k Using Motul 8100 X-clean Engine Oil & Subaru Oil Filter $475
*On Automatic Transmission Cars, we will do a drain and fill of the fluid and replace the ATF Filter (Spin on Type), cost for AT cars is $45 Extra due to Fluid and Filter costs.
**On Forester $20 extra due to plug placement.
Services Included in our 60K Mile Service
Replacement of:
Air Filter
Rotate Tires
NGK Spark Plugs
Clutch Fluid
Pricing:
Non-Turbo Engines H6 add $70 (serpentine belt, oil)
60k Using Conventional Engine Oil & Subaru Oil Filter $525
60k Using Motul 8100 X-clean Engine Oil & Subaru Oil Filter $570
Turbo H4
60k Using Conventional Engine Oil & Subaru Oil Filter $600
60k Using Motul 8100 X-clean Engine Oil & Subaru Oil Filter $650
*On Automatic Transmission Cars, we will do a drain and fill of the fluid and replace the ATF Filter (Spin on Filter Type), cost for AT cars is $45 Extra due to Fluid and Filter costs.
***On H6 Models $35 extra due to plug placement and quantity.
Services Included in our 90k Mile Service
Replacement of:
Air Filter
Rotate Tires
Clutch Fluid
Pricing:
Turbo
90k Using Conventional Engine Oil & Subaru Oil Filter $485
90k Using Motul 8100 X-clean Engine Oil & Subaru Oil Filter $530
90k Using Conventional Engine Oil & Subaru Oil Filter $440
90k Using Motul 8100 X-clean Engine Oil & Subaru Oil Filter $475
Services Included in our Timing Belt Service
Replacement of:
Timing Belt
Timing Belt Tensioner
Timing Belt Pulleys
Water Pump
Thermostat
Coolant Flush
Timing Belt Service Pricing:
Turbo
Timing Belt Service $775
Timing Belt Service (when combined with a 90k service) $725
Non-Turbo
Timing Belt Service $745
Timing Belt Service (when combined with a 90k service) $695
Oil Changes
Motul 8100 X-clean 5w30 w/Subaru Oil Filter $90
Standard Conventional Oil 5w30 w/Oil Filter $50
Bring your own Oil/Filter Change $40
Coolant Changes
Subaru Long Life Coolant Drain/Fill $125
Subaru Super Long Life Coolant Drain/Fill (100k Blue Subaru Fluid) $165
Gear & Transmission Changes (labor only)
Subaru 5MT Front Diff, Trans - Subaru HP $75
Subaru 6MT Front Diff, Trans - Subaru HP $85
Add Rear Diff $35
Subaru 4EAT or 5EAT ATF - Subaru ATF $80
Add Front and Rear Diff $70
Add Subaru ATF Spin on Filter $10-50
BRZ/FRS 6MT Trans Subaru HP $75
BRZ/FRS Rear Diff $45
5MT/6MT Clutch Labor
Clutch & Flywheel Labor Only $550
Add Front Diff, Trans Subaru HP $75
5MT Flywheel resurface (single mass) $90
6MT Flywheel resurface $70
Misc Services (labor only)
AC/Alt-PS Belts (Per Belt except 08+ WRX AC) $30
Spark Plug Replacement Turbo (4) add $25 for OBXT/Forester $200
Compression Test Turbo (4) add $25 for OBXT/For $235
Compression Test Non Turbo (4) $150
Spark Plug Replacement Non Turbo (4) $100
Springs/Shocks/Struts
Springs/Struts/Shocks (Labor Only) $300
Koni Sport Struts Inserts (Labor Only) $400
Coil Over Install and ride height set $400
CV Joints/Axles/Wheel Bearings
Drive Axle w/CV Joint (Labor Only) $100
Sway Bars
Rear Sway Bar w/o Mounts (Labor Only) $100
Front Sway Bar (Impreza '02+, Legacy '05-'09) $100
Standard Engine Rebuilds
CP Forged Pistons w/Rings
King Bearings Rods
King Bearings Main
ARP head studs
11mm Sti oil pump
Timing kit w/water pump
OEM Gasket Kit
Bore/Hone w/torque plates
3 angle valve job, adjustment, resurface, cleaning of heads
Service intake AVCS gears
OEM PCV assembly
OEM T-stat
NGK plugs
OEM Coolant
Oil (10 qts Motul Break in oil)
2 x OEM Oil Filter
Labor
$6400
Brakes
Standard Fluid Flush (labor only) $70
ATE Type 200 Fluid Flush $125
ATE Fluid Flush + Stainless Steel Line install (02-07 Impreza) $225
ATE Fluid Flush + Stainless Steel Line install (08+ Impreza) $250
ATE Fluid Flush + Stainless Steel Line install (05-09 Legacy) $300
Front or Rear Pads Installed $100
Front and Rear Pads Installed $170 w/fluid flush (labor only) $220
Front Rotors and Pads Installed $200
Front and Rear Rotors and Pads $300 w/fluid flush (labor only) $350
Coolant Related Items
Radiator Replacement (Labor) $200
Accessory Related Items
Alternator (Labor Only) $100
Misc Items
Subaru Valve Cover Gaskets (Labor both sides) $400
Subaru Head Gaskets Non-Turbo SOHC Engines (Parts & Labor Estimate) ~$2,500
Subaru Head Gaskets DOHC Engines (Parts & Labor Estimate) ~$3,800
(If the Heads need reconditioning additional charges may apply)
Parking Brake Adjustment $50
Prices valid on stock vehicles in good working condition (no major rust, broken bolts, etc). Prices are labor only, materials extra (unless otherwise noted).
infamousperformance.net is offline   Reply With Quote
Old 02-28-2011, 07:50 PM   #2
Bishop
Super Ninja
Bishop's Avatar
Fav Mod: Deadbolt Super16G
SoCalSubies Addict since: Oct 2006
Bishop is progressing nicely
Welcome!
Bishop is offline   Reply With Quote
Old 03-01-2011, 07:26 AM   #3
Authorized Vendor
Fav Mod: Custom
Thanks.
We have been on the forum for a while (under different user names) just not heavy posting.
We attended last summers S3 event and brought a few LGT's with us.
We are very well known on the Legacy forums and are finally growing.
Old 03-02-2011, 07:28 AM   #4
Authorized Vendor
Fav Mod: Custom
We offer installation and tuning for everything we sell.
Old 03-04-2011, 10:55 PM   #5
Authorized Vendor
Fav Mod: Custom
Tax Season Sale!!! Use promo code "April14" at checkout for 10% off during the entire month of April.
The Koni Shock Value Sale is going on until May 31st. Take 25% off all Koni yellow shocks!!! No promo code required. Free shipping on orders over $299 too!
April14 Promo code can not be combined with any other offers and is not valid on Subaru OEM parts.
Old 03-07-2011, 06:40 AM   #6
Authorized Vendor
Fav Mod: Custom
rainy day bump.
Old 03-09-2011, 08:07 AM   #7
Authorized Vendor
Fav Mod: Custom
Booked through Saturday. Appts for next week available.
Old 03-13-2011, 12:11 PM   #8
Authorized Vendor
Fav Mod: Custom
Sunday, I lost an hour bump.
Old 03-16-2011, 08:15 AM   #9
Authorized Vendor
Fav Mod: Custom
hump day bump.
Old 03-18-2011, 02:54 PM   #10
Authorized Vendor
Fav Mod: Custom
Friday bump. Weekend is booked. Taking appts for next week.
