Nicole's - DC2 Race Car Build - Page 4 - Socal Subaru Forum For SoCal Subaru Enthusiasts: SoCalSubies.com
Old 04-20-2015, 11:19 PM   #31
D3300
making examples of you
D3300's Avatar
Fav Mod: the driver
SoCalSubies Addict since: Apr 2008
D3300 is setting a good example
Default Future Engine Build?!?!
I keep entertaining the thought of building another N/A build along with a forced induction build. It might be a while... or maybe in the not so distant future?!?!
Possibly another B20 Vtec build?
I'm saying nothing for the good of myself, but I'm still talking and you're not listening.
Track Build By: John @Corner Speed Tuning
D3300 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-20-2015, 11:34 PM   #32
Kevin
Site Owner
Kevin's Avatar
Car: 08 AW Project STI
Fav Mod: Crawford Performance
SoCalSubies Addict since: Oct 2006
Kevin is setting a good example
oh dang
Spare parts: www.subiedeals.com | Subaru stuff on eBay
Kevin is offline   Reply With Quote
Old 04-22-2015, 10:30 AM   #33
Corner Speed Tuning
Authorized Vendor
Corner Speed Tuning's Avatar
Car: 06 STI
SoCalSubies Addict since: Feb 2015
Corner Speed Tuning is learning the ropes
Acura in a subie graveyard. Time for some more updates.
FB:Corner Speed Tuning
IG: Corner Speed Tuning
PH: 714-892-2525
Corner Speed Tuning is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-22-2015, 08:42 PM   #34
bue car
Official Postwhore
bue car's Avatar
Fav Mod: Member #264
SoCalSubies Addict since: Mar 2008
bue car is setting a good example
woot updates!
My Builds:
1995 Impreza L with full 2000 2.5 RS Swap (Rally)
1995 Impreza Base (DD)
2007 STi (Weekend /Track) - under construction
bue car is offline   Reply With Quote
Old 02-05-2016, 01:30 PM   #35
D3300
D3300's Avatar
Fav Mod: the driver
Default Spark plugs, spark plug wires, cap and rotor and compression test
Playing catch up with my journal again.. :P
The car was acting a bit on the sluggish side so i decided to change the spark plugs, spark plug wires, cap and rotor. Previous owner seems like they only did maintenance only if the car needed it. Didn't really keep up with it good like i would but hey that's why she is here now. I also wanted a compression test done since we would be in the area, just to know everything is good under the hood. Unfortunately I can't find the numbers from the compression test but everything checked out good. When i do find the paper with the numbers i will update this post. The car really needed these parts badly, the car felt so refreshed after.
Today's installs:
Removing the old spark plugs
Compression test, since the spark plugs were out
Replacing cap and rotor
old crusty gasket vs. new
old spark plugs vs. new spark plugs
New spark plug wires
All done!
Old 02-05-2016, 05:21 PM   #36
D3300
D3300's Avatar
Fav Mod: the driver
Default Hawk hp+ brake pads, Centric rotors, StopTech brake lines, Motul brake fluid
When I was inspecting the brake pads noticed they were kind of getting low. I decided to order Hawk HP+ pads and new Centric blank rotors. I figured might as well order the stainless steel brake lines front and rear and do a flush on my car. Since I didn't know the last time it was done on this car might as well do it now. For brake fluid i usually ordered ATE Super blue but since that was deemed illegal to use in the US i had to find something just as good and I ended up purchasing Motul RBF 600. I have heard nothing but good things and read up on the fluid and it also had a higher boiling point tolerance than Super Blue.
Today's installs:
Dirty dirty brake fluid
Old front
Old rear
Old vs. New front
Old vs New Rear
Let the brake flush begin!
Look at what was coming out!! It was gross, i couldn't believe how dirty it was.
StopTech stainless steel lines installed
Old vs new front
Old vs new rear
All done! Looks so good
Went for my usual ritual after a great install!
Old 02-08-2016, 08:49 AM   #37
Terrible Juan
Terrible Juan's Avatar
Fav Mod: Torque Steer
SoCalSubies Addict since: Aug 2009
Terrible Juan is setting a good example
Awesome updates. Sometimes updating the basics on your car (plugs, wires, pads, rotors) can be so rewarding even though it's just getting your car running how it should run.
And not trying to be that guy, but I've seen worse brake fluid. Did it smell like fish? Mine did.
terriblejuan.com
Terrible Juan is offline   Reply With Quote
Old 02-09-2016, 07:23 AM   #38
Corner Speed Tuning
Authorized Vendor
Car: 06 STI
Should have this caught up pretty soon. Then we can start getting into the good stuff.
PH: 714-892-2525
Old 02-10-2016, 02:14 PM   #39
djmatao
djmatao's Avatar
Fav Mod: Flared WRC
SoCalSubies Addict since: Jun 2009
djmatao is enriching the experience of other members
i want to see the goods!
I <3 My Princess Snow White
djmatao is offline   Reply With Quote
Old 02-11-2016, 10:15 PM   #40
D3300
D3300's Avatar
Fav Mod: the driver
Default Hasport Motor Mount Install
Since i bought my DC2 I knew i wanted to replace the motor mounts. Why did i wait so long to replace these parts, i think it was more of finding the time to do it because i knew the car had to be down for a few. The car felt like the engine was going to fallout from the bottom of the car. The ride wasn't pleasant as i was daily driving the car at the time so even if i had a passenger you can tell in their face it wasn't pleasant. So i finally made the decision on pulling the trigger on the Hasport Motor Mounts because they are the best! I got the Hasport 62A "street durometer" in machined billet non anodized. The motor mount install was pretty straight forward, had everything installed in a few hours. I just couldn't believe that mounts were so wore out that when we took them out the center of the mount just fell out like nothing.
Todays install's:
Old rear orginal OEM motor mount
New rear motor mount
Old vs New rear mount
Rear mount installed
New right mount
Old vs New right mount
Right mount installed
Old left mount
New left mount
Old vs New left mount
Left mount installed
So glad this are NOT in my car anymore the ride is so much better!
Here is a small video clip, SOLID! i wish i would of got a video of it before when it was rocking back and forth... lol
http://vidmg.photobucket.com/albums/...psidxeffii.mp4
